G3 Yosemite, DVD et OS X 10.1
shralldam
Membre habitué
Quelqu'un m'avait demandé de lui expliquer la procédure pour pouvoir utiliser le lecteur DVD sous OS X 10.1 sur un G3 bleu et blanc avec une carte graphique PCI (Rage 128)... Voici ce que j'ai trouvé :
I have a B&W G3 with a PCI Radeon card and the original DVD-ROM drive. As I'm typing this a DVD movie is playing on it with OS X 10.1's DVD Player. Here's how I did it using an already unpacked copy of the player from a G4/AGP system.
I could find the Essentials.pax.pkg, but not a "Essentials.pkg.gz" file that was noted in a reader post below. Since I own several Macs that are "supported" by the 10.1 DVD player, I made a copy of the DVD player from a G4/AGP system here.
1. Running OS 9, I made a duplicate of the DVD Player.app - which makes it appear as a folder vs a file in OS 9. (Hexedit can't open the player.app "file").
2. Using Hexedit I opened the "DVD Player" file that's in the Contents/MacOS folder. I searched for the string "PowerMac2" to find the listing of "PowerMac2.1,.."
3. I changed the "2" in "PowerMac2.1" to "1" (i.e. now reading "PowerMac1.1") and saved the file.
[Note: A G4/PCI Yikes owner noted his ID was "PowerMac1,2"
For Beige G3 info - see this update.]
4. I then renamed the "DVD Player.app copy" folder to "DVD Player.app" and it "changes" back to a single file icon. I copied that file to the B&W G3's OS X 10.1 Applications folder
Voilà. Et si vous voulez récupérer l'application déjà modifiée, il suffit d'aller au lien suivant :
http://edit.briefcase.yahoo.com/bc/slzepeda/lst?.dir=/My+Documents
J'espère que ça dépannera ceux qui sont concernés par ce problème. Il paraît que ça marche même sur les Powerbooks G3.
Voir le profil de l'utilisateur Envoyer un message privé MSN Messenger
