eletonance Membre
bonjour quelqu'un peut vérifier ce script S.V.P
il y des fautes !!!!
merci
copy (choose folder with prompt "what do you want a list of") to thefol
tell application "Finder"
set thelist to every item of thefoll
copy (open for access the file "Macintosh HD:ScriptGenFile" with write permission) to refnum
try
repeat with thefile in the list
write (thefile as string) & "
"to refnum
end repeat
end try
close access refnum
end tell |
