Q Membre
Inscrit le: 07 Mar 2001 Messages: 20 Localisation: de quoi????
Posté le: 3-Juil-03 00:12:17 Sujet du message: STH FW ichat AV |
salut, j'ai suive les indication d'apple pour la config du firewall avec ichat AV mais sans success.
voici ce que j'ai fait
:firewall rule create chain=INPUT index=1 srcintfgrp=wan prot=udp dstport=16403 action=accept
:firewall rule create chain=INPUT index=2 srcintfgrp=wan prot=udp dstport=16402 action=accept
:firewall rule create chain=INPUT index=3 srcintfgrp=wan prot=udp dstport=16401 action=accept
:firewall rule create chain=INPUT index=4 srcintfgrp=wan prot=udp dstport=16400 action=accept
:firewall rule create chain=INPUT index=5 srcintfgrp=wan prot=udp dstport=16399 action=accept
:firewall rule create chain=INPUT index=6 srcintfgrp=wan prot=udp dstport=16398 action=accept
:firewall rule create chain=INPUT index=7 srcintfgrp=wan prot=udp dstport=16397 action=accept
:firewall rule create chain=INPUT index=8 srcintfgrp=wan prot=udp dstport=16396 action=accept
:firewall rule create chain=INPUT index=9 srcintfgrp=wan prot=udp dstport=16395 action=accept
:firewall rule create chain=INPUT index=10 srcintfgrp=wan prot=udp dstport=16394 action=accept
:firewall rule create chain=INPUT index=11 srcintfgrp=wan prot=udp dstport=16393 action=accept
:firewall rule create chain=INPUT index=12 srcintfgrp=wan prot=udp dstport=16392 action=accept
:firewall rule create chain=INPUT index=13 srcintfgrp=wan prot=udp dstport=16391 action=accept
:firewall rule create chain=INPUT index=14 srcintfgrp=wan prot=udp dstport=16390 action=accept
:firewall rule create chain=INPUT index=15 srcintfgrp=wan prot=udp dstport=16389 action=accept
:firewall rule create chain=INPUT index=16 srcintfgrp=wan prot=udp dstport=16388 action=accept
:firewall rule create chain=INPUT index=17 srcintfgrp=wan prot=udp dstport=16387 action=accept
:firewall rule create chain=INPUT index=18 srcintfgrp=wan prot=udp dstport=16386 action=accept
:firewall rule create chain=INPUT index=19 srcintfgrp=wan prot=udp dstport=16385 action=accept
:firewall rule create chain=INPUT index=20 srcintfgrp=wan prot=udp dstport=16384 action=accept
:firewall rule create chain=INPUT index=21 srcintfgrp=wan prot=udp dstport=5060 action=accept
si quelqu'un voie le probleme?
Merci
Q |
Posté le: 3-Juil-03 09:00:18 Sujet du message: |
| et sans pare feu, cela fonctionne ? |
Q Membre
Posté le: 3-Juil-03 09:56:17 Sujet du message: |
non je n'ai pas essayer car je t'avourais que je ne sais pas comment désactivé mon firewall
Je vais creusé ca ce soir sur le site forpage.com il doit y avoir ma reponse.
merci
Q |
